Multifunction DAQ
SCB-68A testing
Hi All,
I am wondering on how to correctly test whether my SCB-68A is working or not? I am affraid my SCB-68A has been damaged.
I am able to detect PCIe 6535 in NIMAX software but I couldn't connect my water level sensor to LabView or NIMAX test panel.
My water level sensor (LVCN 414) is also working fine when I tested it without NI DAQ.
Any help would be appreciated.
Thank you.
(3,813 Views)
Why don't you try "Loopback Test"?
For example,
AI0+ <--> AO0
AI0- <--> AO GND
If you can read correct value, SCB-68A is not damaged.
Certified LabVIEW Developer
GCentral
(3,791 Views)
Hi Emboar,
Thank you for your reply, I searched through this forum right after your reply to my message.
Yes, I did "Loopback" test, I set AO0 to 1 V and create a connection between AO0 and AI0+, and the result was still the same, no matter what number I set for the value, NIMax test panel didn't give me the value I expected. Here is the picture of the test panel.
I read another posting
It might be an indicator that my PCIe is broken, isn't it?
Thank you.
(3,786 Views)
SCB-68A is just terminal block, i don't think it is fragile.
Have you tried DAQ Diagnostic Utility?
DAQ Diagnostic Utility 2.1 - Windows 7 32-bit/7 64-bit/Vista 32-bit/Vista 64-bit/XP 32-bit
Please try another SCB-68A or DAQ card if you have.
GCentral
(3,781 Views)
I don't have more either SCB-68A or PCIe 6323. I checked it with the DAQ Diagnostic Utility software, it passed all the test. However, I didn't get the correct value with the Loopback test. Do you have any other suggestion?
Thank you.
(3,779 Views)
If you cannot measure valid data, SCB-68A would be broken.
Call NI and borrow SCB-68A to check the state.
GCentral
(3,775 Views)
Hi Emboar,
Thank you for your help. I opened a new topic in wiring configuration, maybe my wiring configuration that was wrong. Hopefully, someone will have a suggestion.
Thank you.
(3,767 Views)
