08-18-2005 06:38 AM
08-18-2005 02:24 PM
08-22-2005 07:57 AM
08-23-2005 08:20 AM
08-23-2005 09:12 AM
Thanks!
Does NI 5112 board has digital I/O ? I noted it has analog input CH1, CH2. Traigger (is it analog input, if so, is there any difference between
CH1 and CH2), serial port, PIF something that (is it for digital I/O)
What is the difference between BNC cable and lead cable? BNC cable usually connected to oscilloscope and lead cable can usually connected to DC power supply? They both can measure voltage, why we need to seperate the cable to measure?
I have a power on and off switch, 6 to 4V button, reset butoon, enable button, beep button and shock test button on my test fixture.
Can I use NI 5112 to automatally acquire the signal from the test panel of the Labview using keyboard shortcut key?
08-24-2005 08:20 PM - edited 08-24-2005 08:20 PM
Message Edited by Ayman K on 08-24-2005 08:21 PM
Message Edited by Ayman K on 08-24-2005 08:22 PM
08-28-2005 07:43 AM
08-28-2005 12:16 PM
Wang,
You would use the Trigger input when you want to provide an external trigger that is different from the signals you are acquiring through the two analog input channels.
As for the PFI (Programable Function Input) lines, they are digital but they input and output specific signals. Here is an excerpt from the NI-High-Speed Digitizers Help file that shows the different signals that you can input and output using the PFI lines.
The NI 5112 has two front-panel digital lines that can accept a trigger, accept or generate a reference clock, or output probe compensation to PFI 1.
You can select PFI 1 or PFI 2 on the NI 5112 as an input for a trigger or a reference clock. For example, you can accept a 10 MHz reference clock from an external source rather than using the PXI backplane 10 MHz system reference clock or the clock of another NI 5112 through the RTSI clock line.
You can select PFI 1 or PFI 2 to output the following digital signals:
Ayman K
08-31-2005 07:58 AM
08-31-2005 10:02 AM
Wang,
As indicated in my previous post,
1. PFI is not used to measure signals. It is used as a source of an external clock or for triggering.
2. The difference between input channel 1 and 2 is the name. One is called CH 0 and the other is called CH 1.
3. This question was addressed in another LabVIEW discussion forum posted by you to the LabVIEW team.
4. External trigger is a signal that is used to trigger analog input operations on channel 0 and 1. For instance, if you are acquiring a signal in channel 0 and you only want to read the data when a digital signal is fired (rising edge on a digital line) then you would use an external trigger, connect your digital signal into the trigger line and connect the signal you want to measure in channel 0 or 1. External trigger is not used for measurement, you can not measure signal using the external trigger input.
Ayman K
