Multifunction DAQ
Question about structures
Hello, I have another question abouy labview 6.1 (I only have this version).
My program should generate signal sinewave or a pack of sinewaves then send it to analog out, and measure it on analog in. I will connect the signal from AO to my electronic board and from the electronic board to the AI. And if the maximum value of sinewave wil be higher than 9 volts I should change the resistance in my electronic board so that the amplification won't be that high. To control amplification I woluld like to use digital channels from my NI card and the MAX392 switch on electronic board.
So if the signal on the AI is higher than 9 volts or smaller than 0,5 volts than I should change the digital channel and put "high" on another channel.
I attached my program in labview.
maybe someone can how to do this?
regards
RQsz
PS sorry for my not perfect English
(2,897 Views)
Hello RQsz,
It looks like you are on the right track.  I would recommend using the Write to Digital Line.vi to write a digital high or low value to a digital line of your DAQ card.  You can create a simple algorithm to do a comparison between the value being acquired by your analog input and the limits using the functions in the Comparison palette.  I would also recommend using a while loop to continuously update your analog outputs, analog inputs, and digital line.  Take a look at the attached example program which shows how to perform analog input and digital output continuously in a while loop.  Also, don't forget the many NI-DAQ example programs that ship with LabVIEW that can be found by going to Help >> Find Examples and looking in the Hardware Input and Output category.  Good luck!
Travis G.
(2,873 Views)
