I am attempting to write a Visual C++ application that uses a DACCard-6024E and I have installed the NI-DAQmx 7.4 drivers. Measurement and Automation Explorer has detected the card as "Dev1". An I/O port and IRQ were assigned.
When I do a "Self-Test", I get the following error message.
Error
The device self test has failed. The error report from the device driver is as follows:
Error -200020 occurred at Self Test
Possible Reason(s):
Self-test of the device has failed.
OK
Am I missing a step that will enable the board?
Thanks.
