11-15-2007 09:52 AM
I am trying to install NI-DAQ for NI 9233 but it does not work. I have labview 8.0 and windows Vista 32 BITS. Labview 8 works good until now in this windows, so the problem is with windows, with labview?. I can not install the software NI-DAQ 8.5 or 8.6 because appear this message:
Unsupported version of National Instruments system component detected
Unsupported version of NI-VISA detected
Unsupported version of NI PXI Platform Services detected
Unsupported version of NI-DAQmx detected
Does anybody know what can I do???????????????
11-15-2007
01:35 PM
- last edited on
11-02-2025
10:54 AM
by
Content Cleaner
Rafo-
LabVIEW 8.0 does not "officially" support Windows Vista, and none of the drivers that shipped with LabVIEW 8.0 support Windows Vista. It sounds like you may have installed the NI Driver CD along with your LabVIEW installation. Before installing your Vista-compatible version of NI-DAQmx, you will need to remove any device drivers that you have installed that are not compatible with Windows Vista; this KB entry may help. Ideally you should upgrade your version of LabVIEW to a version that supports Windows Vista- the currently-shipping version of LabVIEW is LabVIEW 8.5, and all software and drivers included with that distribution are compatible with Windows Vista.
Please do not post the same question in multiple threads- a single new thread (or a continuation of this thread) should suffice for any other problems you run into.
Hopefully this helps-
11-16-2007 10:41 AM
11-16-2007 10:44 AM
05-14-2008 03:38 AM - edited 05-14-2008 03:40 AM
I faced with the same problem, either. I am trying to install NI488.2 2.5 for GPIB-USB hardware on a vista computer. The installer gives error massage below.
A version of a National Instruments system component that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. Refer to ni.com/vista for more information.
I uninstalled all NI related programs, and run vista clean up tool. I still get the same error. I even deleted all NI related registry components. Still nothing.
Please help.
regards
Serkan
05-21-2008
03:44 AM
- last edited on
11-02-2025
10:53 AM
by
Content Cleaner
01-30-2009 09:23 AM
My customer is reporting the same problem as Serkanbut posted 05-14-2008.
Unsupported version of National Instruments system component detected A version of a National Instruments system component that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. Refer to ni.com/vista for more information
He has Vista (Korean) and is trying to install my software distribution which installs my executables built with LabVIEW 8.5, LabVIEW run time engine 8.5.1, NI-DAQmx 8.8 and traditional NI-DAQ 7.4.4
I have successfully installed my software distribution on Vista. I can get the above error by installing unsupported NI software, but the error goes away when I uninstall it. My customer formatted the hard drive before installing Vista and did not install any NI software before this. He has checked Control Panel > Programs and found no NI software. He has run the VistaCleanupTool. He still gets the error.
The link suggested to Serkanbut as the answer leads to a thread on a different subject. I cannot find any more help on the knowledge base or discussion forums. All I can think of now is to ask "What actual files or registry entries are checked to cause this message to appear?". |
