02-18-2008 10:10 PM
02-19-2008
06:43 PM
- last edited on
05-06-2024
10:51 AM
by
Content Cleaner
Hi Michael,
I found several links that could be helpful in using the parallel port in LabVIEW:
- Using VISA to Access the Parallel Port in LabVIEW
You can also find an example at National Instruments\LabVIEW\examples\portaccess\parallel port examples.llb. However, I understand that the actual timing of the parallel communication will depend on the operating system. I think it is unlikely that you will be able to achieve the 25 kHz rate with this vis, but it might worth having a look at them. I see that you are already using two M series cards, but we also offer counter/timer cards that could be a better fit for this application. At this point, I would suggest using the PCI-6602 that has 8 counters. I hope this is helpful,
