Example Code
Using VISA to Access the Parallel Port in LabVIEW
Code and Documents
This example uses VISA to write data to the parallel port. NI-VISA 1.1 was the first version that supported parallel communications. If you have an earlier version, this example will not work. When using the parallel port, pins 2-9 are data pins with pin 9 being the most significant bit. Also, pins 11 (printer busy) and 12 (printer out of paper) must be grounded to transmit data.
Comments
cumt-ting
Member
Member
on
Pins 11 and 12 must be grounded to transmit data. I do not know how to do that. Can you help me?
cumt-ting
Member
Member
on
I run the program and there are errors. I do not know how to solve it.
maheshmax007
Member
Member
on
How can we read the staus register of the parallel port
Contributors
