Multifunction DAQ
PXI Controller will not boot when 6071E is in chassis. (new problem).
My PXI contoller stopped upon an acquisition error, and then would not reboot until I removed the 6071E card from the chassis. When I put the 6071E back in the chassis the controller again fails to boot.
(3,360 Views)
Are you using a RT controller?
Even we had similar problem with PXI 6071 E, and we found that the DAQ card was faulty.
Regards
Dev
(3,352 Views)
I agree.  It sounds initially as though it is a faulty card.  I would try the card in a different slot and if possible, try a different card.  If niether of these solves the issue, then I would call in and RMA the card.
-Jeff P.
National Instruments Applications Engineer
(3,341 Views)
