Multifunction DAQ
PCI-6722 output default
Hello, I´m using PCI-6722 and I think something is wrong. If a put a DC voltage in one output channel, when I close the task or clear it and when I reset the card the output still continue to the last value configured. Is this the normal behaviour of the DAQ PCI-6722? This is a problem because I have to configure it to zero volts each time.
Thank you,
(3,557 Views)
Yes it is.
Yow will have to programatically set that particular channel to 0 Volt
(3,549 Views)
Yes it is.
You will have to programatically set that particular channel to 0 Volt
(3,548 Views)
Hi Desirée,
As devchander explains to you and we talk yesterday by phone, the easiest and only way is just to set to 0 the output writing 0 on the output before closing the vi.
The Analog output is only going to reset to 0 when the Power-cycle of the card restarts (for example a rebooting of the PC). Otherwise (PC hangs, vi hangs, LabVIEW hangs, close a vi, close LabVIEW, etc....) the last value is stored and keeped,
Thanks devchander for your answer 😉
Jaime Cabrera
NI Applications Engineering Spain
(3,537 Views)
You are welcome, Jaime Smiley Happy
(3,533 Views)
