10-18-2006 09:54 AM
10-18-2006 10:10 AM
10-30-2006 01:55 PM
10-30-2006 04:06 PM
10-31-2006 02:06 PM
11-02-2006 07:50 AM
12-06-2006 07:58 AM
12-07-2006 07:01 AM
Does the same (unmodified) source code compile and run properly in Windows?
If it does, I won't be able to help you, but if it doesn't, look carefully at your data types and the return codes from the DAQ routines.
Try directly connecting a low frequency square wave generator to the counter and see if it counts properly. For all I know there really could be a bug in the GNU/Linux drivers, NI will have to help you if that's the case. I haven't used the counter function on our boards.
John
12-07-2006 07:22 AM
12-07-2006 03:47 PM
