Multifunction DAQ
NI PXIe-6341 Floating Increasing/Decreasing Voltage Reading
I am having difficulty getting a proper voltage reading on my 6341 Analog inputs.  The inputs seem to show values that don't correspond with that I expect, and the DAQ also seems to force the external voltages low, even when the inputs are all set to tri-state.
When reading with the RSE configuration (because that is how our hardware is set up), I only see an increasing voltage that increases to a random asymptote.  On other configurations, the voltage may be decreasing, or stuck at a single level (that doesn't correspond with the measured value)
Are there any solutions I could try in this situation?
Billy Maier
(4,364 Views)
I am having a similar issue with a 6210. Voltage readings that shouldn't be and read values shifting towards an asymptote (-10.6V for me). I am also using RSE mode. Not helpful I know, but at least you are not alone.
(4,337 Views)
What sort of signal are you trying to measure? How is it physically connected? Do you see this in the MAX test panel? It sounds like a connection problem.
(4,332 Views)
