Multifunction DAQ
input and output differ
I have a pxie-6358 in a pxie-1062 with controller pxie-8360.
when i give a 1V sine wave on ao0 I do not read 1v on ai0.  I have tried with the test panel and the example vi's.  I am not sure why this would happen so am not clear how to start diagnosing the problem.  any help is appreciated.  thanks
Message 1 of 14
(6,055 Views)
First, some more information would be helpfull(my crystal-ball is currently under recalibration 😉 )
How do you apply 1V AC ?
How did you wire the DAQ ?
How did you setup the DAQ ?
AND finally: What did you actually measure?
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 14
(6,053 Views)
using the test panel analog ouput, 10ks/s,100hz
with cable from ao0 to ai0
default test panel
very small, like 30mV...
Message 3 of 14
(6,043 Views)
ok, checked output with other hardware and the output is correct at 1v.
so the analog input reading is false???
Message 4 of 14
(6,039 Views)
Your answers are very vague. You still have not provided the details on your wiring. Provide the actual pin numbers of your connections. And saying you used a default is meaningless. Do you have it configured as differential or rse.
Message 5 of 14
(6,036 Views)
on pxie-1062 the pxie-8360 is connected to slot one.
the pxie-8360 is connected to pci card in the pc.
on pxie-1062 the pxie-6358 is connected in slot 4.
the pxie-6358 is connected via cableshc68-68-epm to bnc-2090A
on the bnc-2090a the AO0 connector is feed direct to AI0 via bnc cable.
in the test panel is select analog output. the channel selected is dev1/ao0, mode: voltage sinwave, transfer mech: default, rate:10000,freq: 10hz {{Verified works}}
on analog input tab the channel dev/ai0 is selected, mode:continuous, input conf: Differential (default, cant change)
rate is 10000hz samples is 1000: i get one sine period in the chart with amplitude 0.035V.
Message 6 of 14
(6,027 Views)
more interesting if i apply 5v.  see attached.
Message 7 of 14
(6,006 Views)
Have you tried analyzing the analog output at the ai0 input terminal with an oscilloscope?
Message 8 of 14
(5,944 Views)
yes, the scope shows exaclty what i request on the analog output.  the ai0 does not.
Message 9 of 14
(5,924 Views)
Have you tried using a different cable to connect the output to the input?
Message 10 of 14
(5,895 Views)
