Multifunction DAQ
NI-DAQmx install problem.
I cannot see the NI-DAQmx in the MAX Device & Interfaces window. The DAQ is listed in the USB devices as Dev1. I mistakenly did the software install with the USB attached to the PC. Every time the PC boots, Windows XP shows a box that a new hardware USB device was found. The Windows XP device manager has a question mark by the "Other devices" and also a "? USB Device" listed. FYI  - I am also running LabWindows 7.1. Any help would be appreciated to get Windows XP and MAX to identify the DAQ USB properly.
David
(3,349 Views)
Hello David,
There are a few things that could be the problem here.  If you are using a USB-6501, 6008, or 6009 you need to be sure to use NI-DAQmx 7.5 or later, because this is the first version of NI-DAQmx that supported these devices.
Another thing to check is that the correct firmware is installed on your device (if it is a 6501, 6008, or 6009).  If the device is used with NI-DAQmx Base, you can follow the instructions in this knowledgebase article to make it compatible with NI-DAQmx.
If neither of these things resolves the issue, then you might try reinstalling NI-DAQmx, while the device is disconnected from the computer.  You can download the latest version of NI-DAQmx here
Please let us know the result.
Laura
(3,326 Views)
Laura,
Thanks for your help. In order to fix the problem I had to rollback the XP pc settings and registry, then uninstall the DAQmx driver, then reinstall the DAQmx driver. Now everything works ok.
David
(3,302 Views)
Hi David,
Thanks for letting us know the result.
Laura
(3,289 Views)
