‎07-30-2006 02:26 PM
‎07-31-2006
01:26 PM
- last edited on
‎07-15-2025
01:05 PM
by
Content Cleaner
Hello David,
There are a few things that could be the problem here. If you are using a USB-6501, 6008, or 6009 you need to be sure to use NI-DAQmx 7.5 or later, because this is the first version of NI-DAQmx that supported these devices.
Another thing to check is that the correct firmware is installed on your device (if it is a 6501, 6008, or 6009). If the device is used with NI-DAQmx Base, you can follow the instructions in this knowledgebase article to make it compatible with NI-DAQmx.
If neither of these things resolves the issue, then you might try reinstalling NI-DAQmx, while the device is disconnected from the computer. You can download the latest version of NI-DAQmx here.
Please let us know the result.
Laura
‎08-03-2006 05:25 PM
‎08-04-2006 02:22 PM
Hi David,
Thanks for letting us know the result.
Laura
