 ZGG
			ZGG
			03-05-2024 06:40 PM
Hi: All
I have one displacement sensor(Brand: HEIDENHAIN; Model:3078), and now, want to capture the signal by NI 9361&cDAQ9174, refer to attachment sensor connector and signal line connection information, no data output from
NI-MAX.
Could you help me to look for the root cause?
BR
Jack.zhao1
Solved! Go to Solution.
 santo_13
			santo_13
			03-05-2024 09:42 PM
Try connecting COM of 9361 to GND of sensor. How are you testing the signal?
03-17-2024 07:41 PM
Hi:Santhosh
Tks for your reply, I tried to connect the sensor signal line with NI 9361 by attachment definition, and configure in the NI-MAX, and now, the sensor with right data output by Ni-DAC block setting up.
BR
Jack.zhao1
