NI 9361 integrated in cDAQ 9174, to capture displacement sensor signal, no data output from NI-MAX
Hi: All
     I have one displacement sensor(Brand: HEIDENHAIN; Model:3078), and now, want to capture the signal by NI 9361&cDAQ9174, refer to attachment sensor connector and signal line connection information, no data output from
NI-MAX.
     Could you help me to look for the root cause?
BR
Jack.zhao1
(709 Views)
Try connecting COM of 9361 to GND of sensor. How are you testing the signal?
Santhosh
Soliton Technologies
(687 Views)
Accepted by ZGG
Hi:Santhosh
     Tks for your reply, I tried to connect the sensor signal line with NI 9361 by attachment definition, and configure in the NI-MAX, and now, the sensor with right data output by Ni-DAC block setting up.
BR
Jack.zhao1
(597 Views)
