Multifunction DAQ
My DAQ Assistant Express VI missing data terminal
I have a PCI card installed and recognized by MAX. I am trying to use DAQ assistant to display the an analog voltage signal on the front panel, but the DAQ assistant does not give me the option to create an indicator. "Create" does not even appear on the shortcut menu when I right click the DAQ assistant on the block diagram. Can someone help me with this? I am using Labview 7.1 with NI-DAQmx 7.2
thanks
(5,017 Views)
duplicate post
please don't post the same question to multiple boards.
(5,014 Views)
I thought it was in the worng section, and can't figure how to delete this one. Anyway, are you going to help me or what?!
(5,007 Views)
I was already helping you before I marked this as a duplicate and before you made this comment.
(5,002 Views)
Thanks for attempting to help me resolve the issue.
(4,988 Views)
