Multiple channel daq
Hi.. I am using usb 6353 DAQ board for my project. I want to acquire 3 different voltages and display it on labview. When i take data from one channel (ai0) in daq assistant it works fine but when i add channels(ai1, ai2) in the task nd run it, the voltages get mixed up. I have used split subvi to seperate the dynamic data, but the readings are all wrong.
What am i doing wrong?
(4,833 Views)
What are the signals you are measuring?  Could you supply some code so we can see how you have it set up?  And what exactly do you mean by "all wrong"?
(4,823 Views)
I am taking voltage from sensor modules.. And by wrong i mean the data from one sensor is affecting the other.
(4,821 Views)
Accepted by Tanya96
So you are seeing ghosting?
(4,812 Views)
It worked. Thank you
(4,776 Views)
