‎11-28-2009 11:50 PM
I am interested in analyzing an microphone input signal in Labview. I have read that you can use a DAQ board to do this.
I am wondering if it is possible to put the signal directly into labview (without using a DAQ board); by just using the 2.5mm jack on the computer, can you get a voltage that can then be fed into Labview for analyzation.
Thank you
Jen
‎11-29-2009 09:37 AM
‎11-29-2009 12:59 PM
Hmm.. It looks pretty simple, but when I try the NI examples or the express VI, I get an error (Hex 0x12CB) Cannot support sound format. The device does match the microphone on my computer, so any ideas on what the problem could be?
Thank you
Jen
‎11-29-2009 03:23 PM
‎11-29-2009 03:32 PM
No. There is only 1 soundcard. The VI does allow you to select the device that you want when you set it up, but device 0 (default) does match the appropriate system for my computer.
Thank you
Jen
‎11-29-2009 04:06 PM
