10-13-2008 09:00 PM
I couldn't use AI ContAcqIntClk example because I only have 2 Analog Inputs and are already used, and I'm reading an Encoder, so It wouldn't help me either.
I don't know what you mean about poll the Available Samples property, what's that, where can I find it?
10-13-2008 10:08 PM
Got it!!
I now have the program doing what I want to, I just deleted Sampling Timming, an voila! It's really boring explaining what i did so i will just post the modifications I did to the Ang_Pos_Buff_Count.c example:
* ANSI C Example program:
* AngularPosition-Buff-Cont.c
* Example Category:
* CI
#include <stdio.h>
#include <stdlib.h>
//#include <conio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; elseint i;
int main(void)
int error=0;
TaskHandle taskHandle=0;
int32 read;
float64 data[10];
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateCIAngEncoderChan(taskHandle,"Dev2/ctr0","",DAQmx_Val_X4,0,0.0,DAQmx_Val_AHighBHigh,DAQmx_Val_Degrees,360,0.0,""));
// ADJUSTED THIS LINE TO MY DEVICE
//DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/Dev2/PFI8",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
// I JUST DELETED (SLASHED) THE LINE ABOVE
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
printf("Continuously reading. Press Ctrl+C to interrupt\n");
while( 1 ) {
// DAQmx Read Code
DAQmxErrChk (DAQmxReadCounterF64(taskHandle,1,-1,data,10,&read,0));
// AND CHANGED SOME OF THEESE SETTINGS
printf("Acquired %d samples\n",read);
//for (i=0;i<read;i++)
system("CLS");
printf("%f, ",data[i]);
fflush(stdout);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
Pretty simple stuff, but it took me a long time to get here since i didn't know anyting about programming daqmx with vc++, I just want to thank Neil, Arturo, BeCeGa, and many others who have helped me, Thank you guys. Now I will continue working on vc++ windows interface to complete my project, as well as so many other things about daqmx, so I will keep disturbing you guys
ZZ
10-15-2008 08:42 AM
I'm glad you got it working. Don't hesitate to post to the forums again if you get stuck. We are here to help.
Neil S.
