Measuring Angular Position with vc++
I couldn't use AI ContAcqIntClk example because I only have 2 Analog Inputs and are already used, and I'm reading an Encoder, so It wouldn't help me either.
I don't know what you mean about poll the Available Samples property, what's that, where can I find it?
Message 11 of 13
(1,059 Views)
Got it!!
I now have the program doing what I want to, I just deleted Sampling Timming, an voila! It's really boring explaining what i did so i will just post the modifications I did to the Ang_Pos_Buff_Count.c example:
* ANSI C Example program:
* AngularPosition-Buff-Cont.c
* Example Category:
* CI
#include <stdio.h>
#include <stdlib.h>
//#include <conio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int i;
int main(void)
int error=0;
TaskHandle taskHandle=0;
int32 read;
float64 data[10];
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateCIAngEncoderChan(taskHandle,"Dev2/ctr0","",DAQmx_Val_X4,0,0.0,DAQmx_Val_AHighBHigh,DAQmx_Val_Degrees,360,0.0,""));
// ADJUSTED THIS LINE TO MY DEVICE
//DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/Dev2/PFI8",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
// I JUST DELETED (SLASHED) THE LINE ABOVE
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
printf("Continuously reading. Press Ctrl+C to interrupt\n");
while( 1 ) {
// DAQmx Read Code
DAQmxErrChk (DAQmxReadCounterF64(taskHandle,1,-1,data,10,&read,0));
// AND CHANGED SOME OF THEESE SETTINGS
printf("Acquired %d samples\n",read);
//for (i=0;i<read;i++)
system("CLS");
printf("%f, ",data[i]);
fflush(stdout);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
Pretty simple stuff, but it took me a long time to get here since i didn't know anyting about programming daqmx with vc++, I just want to thank Neil, Arturo, BeCeGa, and many others who have helped me, Thank you guys. Now I will continue working on vc++ windows interface to complete my project, as well as so many other things about daqmx, so I will keep disturbing you guys Smiley Happy.
ZZ
Message 12 of 13
(1,057 Views)
I'm glad you got it working.  Don't hesitate to post to the forums again if you get stuck.  We are here to help.
Neil S.
Message 13 of 13
(1,038 Views)
