Multifunction DAQ
Maximum Input current for 6210 /-10V Range
What is the input current spec for the NI USB 6210 when making a single ended (i.e one of its 16 channels) reading in the +/-10V range? I need to quantify the error in a voltage divider I am using to measure a 200VAC ground referenced signal, since part of the current through the voltage divider is splitting off to drive the ADC input on the 6210.
(3,032 Views)
Accepted by @dave@
From the specs document:
Input impedance
Device on
AI+ to AI GND ......................>10 G
with 100 pF
AI– to AI GND.......................>10 G
with 100 pF
Device off
AI+ to AI GND..................1200
Ω in parallelΩ in parallelΩ
AI– to AI GND ..................1200
Ω
Input bias current.............................±100 pA
I presume the +/-100pA is from 10V/10Gohms. I doubt that the 6210 will load down the divider.
-AK2DM
(3,030 Views)
