M Series, Analog Edge Trigger condition
Hi
I am currently developing an application which measures some voltage values. Now I received the following message:
--snip--
Device supports an analog channel as the source of an analog reference trigger only when it is the only channel in the task.
Remove all of the channels currently in the task except the channel that will be used as the analog trigger source, or change the analog trigger source to a terminal.
--snip--
I need to measure all 4 channels based on that reference trigger. Now my question: How would I do that? The physical channels control is set to 6250/ai0:3. I also export the signal to the RTSI Line #1 which triggers 2 other cards (one 5122 digitzer card, one 6120 S series)
(2,939 Views)
(2,925 Views)
