Multifunction DAQ
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Installing NiDaq on Windows 7
I am trying to install Traditional Ni-Daq on a windows 7 computer using the beta 7.5 found at the link below but i keep getting a message that says the downloaded file is not a valid windows 32 application.
I am using a 32bit W7 computer
This is a temporary solution that will soon but updated to DaqMX.
http://research.ni.com/run/ogtraditionaldaq
0 Compliments
Message 1 sur 10
5 899 Visites
I tried downloading it (it doesn't install on my 7 64-bit machine, of course), but it downloaded fine and extracted just fine. Does it allow you to extract the files? Maybe try another browser or clicking the file yourself...
Have you attempted to download again? Maybe the file corrupted in flight depending on your internet connection...
0 Compliments
Message 2 sur 10
5 891 Visites
It does not allow me to extract the files, the first thing it says is that it is not valid.
Are you downloading the .exe file or is it a .zip?
The one it gave me was a .exe
0 Compliments
Message 3 sur 10
5 879 Visites
Alright, i tried installing this on my W7 64bit machine and it unzipped successfully.  I didn't continue with the operation since i knew it wouldn't install.
Anyone know why this would have problems on a 32bit machine.  The computer is fresh and the only program installed was LabVIEW.
0 Compliments
Message 4 sur 10
5 874 Visites
I was able to extract and install this file on my 32-bit machine. If you were unable to even extract the files on your 32-bit machine, one thing to try is extracting them on your 64-bit machine and then copying the installation files onto your 32-bit machine.
Message 5 sur 10
5 857 Visites
Worked like a charm, thanks.
0 Compliments
Message 6 sur 10
5 840 Visites
I am installing the NIDAQ 9.8.0 on my 32 bit machine. But it says, The NI ethernet device enumerator installation has failed.
I cannot continue with the installation.
pls help. Thanks in advance.
0 Compliments
Message 7 sur 10
5 650 Visites
NIDAQ does not work on W7 unless you are using the 7.5 beta versions.   As explained earlier in the thread, you have to unzip the files using a 64 bit machine then transfer the folder to your 32 bit machine.
Are you using W7, W8 or XP?
0 Compliments
Message 8 sur 10
5 643 Visites
There is no such thing as NIDAQ 9.8.0. Do you really mean DAQmx? If so, you hijacked a completely unrelated thread and should start a new one.
0 Compliments
Message 9 sur 10
5 639 Visites
Thanks for the quick reply.
Yes it is Ni DAQmx on windows 7.
0 Compliments
Message 10 sur 10
5 627 Visites
