11-12-2007 02:29 PM
03-27-2008 07:24 PM
Dear Paul or anybody else who may help!
I have a USB-6211 DAQ and Labview 8.5, and NIDAQmx version 8.71 (the latest one?), running on windows XP
The attached VI exits after about 4 seconds of execution with the overflow error: Error -200279 occurred at DAQmx Read (Analog 1D Wfm NChan NSamp).vi:1
The example is very simple, involving a single loop containing a single channel AI (continuous sampling at 40 samples at rate of 4000 samples/sec), in parralel with a single channel AO, writing a DC value at 10 samples at 1000 samples/sec.
Thus, both read and write should take about 100 mSec per iteration- still the AI buffer gets overflow after just 4 seconds. It is the same phenomenon even if i lower the AO write samples (from 10 to 5 for example)
Could the problem arise from the use of the DAQ assistants instead of the more primitive read/write functions? Shouldn't this also work with the DAQ assistants?
Any help would be greatly appreciated!
PS the problem persists when i changed the AO write rate to 4000 to equal the AI rate
PPS the problem disappears if i disconnect the wire between the simulate signal and the AO daq assistant - meaning the problem resides in the daq assistant or its workings
