Multifunction DAQ
BNC Cable
I want to control a servo motor with BNC 2110 and 6024E.
For motor control, I need an analog output signal and its references.
For this aim, which type of BNC cable can be used?
Regards.
(3,224 Views)
Hi kadikoy,
Most BNC cables are made with a coax wire. The outer part of the BNC connector is connected to the wire’s shield and the inner pin is connected to the center conductor. This type of cable will work fine for your application. The analog output voltage will be on the center pin and the ground reference will be the outer shield.
What type of servo motor are you using? Most servo motors are controlled using a digital pulse where the pulse width specifies the position of the servo. This can be done using a counter output task. Are you using a servo motor controller that needs an analog voltage?
Let me know if you have any questions.
Nathan
NI Chief Hardware Engineer
(3,205 Views)
Thanks a lot. I understood
I will conroll motor torque in my applicaiton. Because of this I will planning using analog outputs.
Best Reagrds
(3,188 Views)
