Multifunction DAQ
How do I programmatically export a graph as an image
How do I programmatically export a graph as an image using the elapsed time vi?
(2,912 Views)
You use the Get Image method and wire the results to the Write JPEG File (or Write BMP/Write PNG). On your Report Generation palette, you can look at the Append Control Image to Report function.
p.s. In the future, questions of this type should be posted to the LabVIEW board and not Multifunction DAQ.
Message Edited by Dennis Knutson on 05-07-2007 01:25 PM
Message Edited by Dennis Knutson on 05-07-2007 01:26 PM
(2,909 Views)
