I have a NI USB 6218 DAQ unit. When I try to output a voltage on the analog output channels, I am unable to output less than 3.38V on AO0 but voltages above 3.38 output fine (I can get 5V, 7V et cetera) and my ouput is always off by 0.25V on AO1 (0V measures 0.25V, 5V measures 5.25V et cetera).
I am using a Metex M-3650 digital multimeter to measure the voltage. I attach the red cord to one analog output channel and the black cord to the analog output ground.
I tried running the self calibration and it failed prompting me to perform an external calibration.
Is there an easy way to fix my analog output channels? Also, is there any standard method to test my analog input channels to make sure the problem has not affected my input channels as well.
Ali
