Multifunction DAQ
How can I read a quadrature encoder using a 6036E PCMCIA card?
I have PCMCIA 6036E card and I want to read a quadrature encoder.
I do not need to use the z index.
My version of Labview is 8.5.
When I try to use the DAQ assistant and choose the "angular position" option I get the reply that no supported devices were found.
What should I do?
Thank you in advance,
Fotios
(3,086 Views)
Accepted by fotis_k
The PCMCIA-6036E card has a STC-Chip that doesn't support position encoding since there is no Z support. It has to be solved in software, and using edge counting.
Some info about E-cards and quadrature encoding:
http://zone.ni.com/devzone/cda/tut/p/id/4623
http://zone.ni.com/devzone/cda/tut/p/id/2879
http://zone.ni.com/devzone/cda/epd/p/id/1427
/Klas
(3,036 Views)
