Multifunction DAQ
maximum input voltage on PCI-6033E
We are using PCI-6033E cards for measuring the voltage drop across switches destined for use in automotive applications. This application requires that the cards withstand voltages of +13.5V. It is not necessary for the cards to actually read the value it is only necessary that it can withstand being subjected to this voltage.
Until now we have been working fine with this setup. We now need to test at voltages of up to 30V. Is it still safe to work with these cards or will we need to use different cards?
(2,860 Views)
The specs are here.
(2,859 Views)
