02-25-2015 08:18 PM
Hi there, I need to take temperature and humidity measurement from several locations. Initially I have selected NI 9213 that attached through NI cDAQ 9174. Now I'm planning using a probe from Michell http://www.michell.com/uk/documents/PCMini52_97176_UK_Datasheet-V4.pdf but I'm not sure if it compatable with the module selected. If not which module you recommed?
06:30 AM
- last edited on
04-30-2024
08:11 AM
by
Content Cleaner
That module is made for thermocouples, which your probe is not. So I would just use a standard AI module. Do you have other modules in your cDAQ chassis? If not, I would just use something like the USB-6000.
02-26-2015 08:02 AM
I dont have any other module yet since I need to select and buy the correct module for this experiment. Do you have other recommendation since I need to put at least 8 sensor on the module?
02-26-2015
09:11 AM
- last edited on
04-30-2024
08:12 AM
by
Content Cleaner
I recommend you start here: http://sine.ni.com/np/app/main/p/bot/no/ap/daq/lang/en/pg/1/sn/n17:daq,n21:41,n24:USB/
From there, you can widdle down which device to use based on your requirements.
