Hardware selection
Hi there, I need to take temperature and humidity measurement from several locations. Initially I have selected NI 9213 that attached through NI cDAQ 9174. Now I'm planning using a probe from Michell http://www.michell.com/uk/documents/PCMini52_97176_UK_Datasheet-V4.pdf but I'm not sure if it compatable with the module selected. If not which module you recommed?
(4,658 Views)
That module is made for thermocouples, which your probe is not.  So I would just use a standard AI module.  Do you have other modules in your cDAQ chassis?  If not, I would just use something like the USB-6000.
(4,643 Views)
I dont have any other module yet since I need to select and buy the correct module for this experiment. Do you have other recommendation since I need to put at least 8 sensor on the module?
(4,638 Views)
I recommend you start here: http://sine.ni.com/np/app/main/p/bot/no/ap/daq/lang/en/pg/1/sn/n17:daq,n21:41,n24:USB/
From there, you can widdle down which device to use based on your requirements.
(4,633 Views)
