Hello Jimmy,
Thank you for contacting National Instruments.
You can easily generate a pulse or a pulse train from your DAQ board using LabVIEW 7.0. If you choose to generate this output on counter 0, you will most likely need to connect to pin #2. If you choose to use counter 1, you will most likely need to connect to pin #40. You can connect to any of the DGND signals for a ground reference. These are pins: 35, 36, 4, 39, 9, ...
In order to actually program your board, I recommend that you use our DAQmx driver. I have attached two example programs below. One demonstrates how to generate a pulse and the other generates a pulse train. You can find these examples on your machine by going to Help >> Find Examples >> Hardware Input and
Output >> DAQmx >> Generating Digital pulses
You will not be able to have the signal be independent of your PC. First, the board must be programmed by your PC to start and stop the output. Secondly, your DAQ board is powered by your PC power supply. If you turn off the PC, you will effectively turn off your board.
Let me know if you need any additional assistance with this issue.
Bill B
Applications Engineer
