Multifunction DAQ
Generate a continuous pulses from digital output port with external clock source
I had a USB 6353 DAQ board.  I want to set AO sample clock from an external clock source (PFIx) and set the programmable Clock Divider to an integer number like the following:
What is/are functions should I use?
(278 Views)
In LabVIEW, you would use a DAQmx Timing property node to set:
Sample Clock.Timebase.Source
Sample Clock.Timebase Divisor
-Kevin P
Present job ending soon. Need DAQ expertise? PM with serious opportunities.
(244 Views)
Hi Kevin,
  Thanks for your help.  I solve the problem in C# by setting the sample source, divider like you did in Labview.
(190 Views)
