Generate a continuous pulses from digital output port with external clock source
I had a USB 6353 DAQ board.  I want to set AO sample clock from an external clock source (PFIx) and set the programmable Clock Divider to an integer number like the following:
What is/are functions should I use?
(352 Views)
In LabVIEW, you would use a DAQmx Timing property node to set:
Sample Clock.Timebase.Source
Sample Clock.Timebase Divisor
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW?
(Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(318 Views)
Hi Kevin,
  Thanks for your help.  I solve the problem in C# by setting the sample source, divider like you did in Labview.
(264 Views)
