Multifunction DAQ
Error -200361
Given that you've tried this on 2 PC's and are using an example program, you may need to call and speak to an applications engineer to discuss the possiblity of a hardware problem. You should be able to use (866) 275 6964.
-Alex
Message 11 of 15
(1,571 Views)
I have got another USB 6009, but result is same. I got error -200361 when i mimize and maximize the application windows While my cpu usage is just 21% maximum.
If i don't disturb the application windows, it works fine fore ever without giving any error. But when i run any other application or any just refresh the application windows by puting another application on it, it gives me error.
Please note that i am trying with example .vi only and with sampling rate of 20KSa.
Please suggest me what am doing wrong ?.
Message 12 of 15
(1,552 Views)
I've seen cases where DAQ systems were running very close to the edge. So close that even the slightest movement of a window or opening an application would cause a buffering error. I'd be very interested in seeing your code. When you post your code, be sure to tell us what values you are using for the front panel inputs.
I can run your code over here and see if I get the same result.
-Sal
Message 13 of 15
(1,532 Views)
Here i have attached code which i am using for testing USB-6009.
All the parameters are default. Please have a look into it.
-Gaurav
Message 14 of 15
(1,515 Views)
Gaurav,
This behavior you are experiencing is a result of a combination of factors. 1) The 6008/9 has a very small onboard FIFO. 2) NI-DAQmx Base is a driver written in the user level. 3) Communication with the device is message based over USB which is inherently slower than equivalent communication over PCI. Since NI-DAQmx Base is written in LabVIEW, it has user level priority and CPU allocation. If the operating system is busy with other user level operations, NI-DAQmx Base can get starved of resources so that it cannot request data from the USB device fast enough. Since the USB-6008/9 has a relatively small onboard FIFO, it does not take long for the FIFO to overflow if you are acquiring at a high rate. Unfortunately, the operations you mentioned (e.g. opening other programs, minimizing/maximizing windows) are very CPU intensive, especially with Windows OS. Therefore, when you perform these operations, NI-DAQmx Base cannot retrieve data from the device, the FIFO overflows, and you get the -200361 error. The best solution, currently, is to minimize all other operations on the computer in order to prevent this potential starvation of NI-DAQmx Base. We are investigating other solutions that may be available in future versions, including providing driver support in the kernel level to prevent this kind of resource starvation.
Message 15 of 15
(1,509 Views)
