Multifunction DAQ
Error -200288 occurred at DAQmx Write
Hi all I get this error
Possible reason(s):
Attempted to write a sample beyond the final sample generated. The generation has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample generated. The final sample generated can be determined by querying the total samples generated after a generation has stopped.
Attempted to Write Sample: 5001
Property: RelativeTo
Corresponding Value: Current Write Position
Property: Offset
Corresponding Value: 0
Task Name: Output
whe i write the second time a wafeform to the analog output
How can I fix this problem ?
Any help
Jürgen
PS
LabVIEW 2009 SP1
(7,183 Views)
(7,179 Views)
Hi Jürgen,
what hardware are you using? What are your channel settings in MAX? And what is your value for the control "Zeit ( sec )"?
Please have a look at the code I attached.
Stefan
(7,170 Views)
Thanks for your help
It brought me on the right track
Now it is working with small problem
when I start the waveform a second time with the same time nothing is happend but when I change the time a bit then it works again fine
Zeit are in secund
I am using LabVIEW  2009 SP1
USB 6215
I define the task in my INIT.VI
Jürgen
(7,157 Views)
Can you show your updated code and explain what "change the time a bit" means?
Tim
GHSP
(7,128 Views)
Hi See the attachment
Call the VITest.VI and run the VI
Press the button "Messung dynamisch"  motor is running
then press the button again mot is doing nothing and no error
then change the in the control "Zeit (sec) " the time to 5 and press the button "Messung dynamisch" motor is running again
So when you change the in the control "Zeit (sec) " then the motor is running
I hope that's explain it
Jürgen
(7,103 Views)
One thing that I see is that you need to change the tunnel on the read analog task to a shift register. Connect the task on both sides.
In the top loop the wait is not required since you are using the event structure.
19261i67EAF2B6692C1655
Tim
GHSP
(7,091 Views)
