From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
DAQmx concurrent tdms read
i am measuring a voltage using the NI9223 and log the data to a tdms file. Since my signal processing takes a lot of time, i try to read the tdms file while the measurement is still active.To do this, I modified the "Concurrent Access to TDMS file" example.
Unfortunately the TDMS Read VI always responds wit a error:
LabVIEW: End of file encountered.
NI-488: Invalid argument or arguments to function call.
I already tried different offsets and data lengths (-1) but nothing seems to work.
Thanks a lot for your help
(2,813 Views)
Accepted by katratzi
DAQmx has exclusive access to the TDMS file during the logging process.  That is one of the reasons it can log data faster than a Producer/Consumer.
For your exact example, you should be using the Log And Read mode and use the DAQmx Read inside of the loop to then write to your chart.
GCentral
(2,791 Views)
