Multifunction DAQ
USB-6210 with C/C++ in Linux
Hey,
I'm interested in the USB-6210 to use for my Bachelor's thesis. Unfortunately, I cannot buy any licences for LabVIEW and I have to work with Linux only. Are there any (open-source) options to simply measure 5 diff. channels of the 6210 with Linux? I'm thinking of C/C++... Maybe there are some libraries or even example codes available?
Thanks!
C.Cr
(4,977 Views)
Hi!
yes the driver the USB-6210 uses is the NI-DAQmx driver. The driver features a ANSI C and .NET API beside the LabVIEW support.
NI-DAQmx 16.0 Readme - National Instruments
https://www.ni.com/pdf/manuals/374768k.html
You can download the DAQmx API for free and if you install the MAX (Measurement & Automation Explorer) you can also simulate a USB-6210 and test if your driver call work.
Download:
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288254
You find a lot of documentation for DAQmx for ANSI C & .NET and also there are a lot of examples that install with the NI-DAQmx driver:
Location of ANSI C NI-DAQmx Shipping Examples and DAQmx Library File for Windows
Using NI-DAQmx in Text Based Programming Environments
Where Can I Find Documentation for DAQmx Functions in All Visual Studio Environments?
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,941 Views)
Well, thanks for the effort I guess, but I'm not sure if I'm just stupid or if this is a major misunderstanding. As far as I can see, all the links are aimed at Windows users. Unfortunately, I cannot use Windows. That's why I'm asking...
Regards
C.Cr
(4,933 Views)
Sorry, I didnt see the 'Linux', only the no LabVIEW part.
There is also a DAQmx Linux driver called DAQmx Base:
NI-DAQmx Base 15.0 - National Instruments
https://www.ni.com/en/support/downloads/drivers/download.ni-daqmx-base.html#326059
There are some limitation (see readme for that), but in general you can follow most (Windows) tutorial for the C API.
Christoph
(4,930 Views)
No problem! I'll look into that, Thanks 🙂
C.Cr
(4,926 Views)
