‎03-15-2006 05:38 AM
‎03-15-2006 10:43 AM
‎10-29-2007 07:21 AM
hi
i m getting the same error in my DAQ system...I m in search of this problem since last 4 days...i have tried all the solutions available in NI forum....
First of all, I am telling you the problem what i m facing is....
a) I have tried to decrese the sample per channel bt i need only that much sample per channel.so that solution is not full fil my problem
b) I have tried to increase the buffer size using DAQmax buffer bt after reaching to that much of buffer, it becomes full and again i m getting the same error..so i need one logic that empty my buffer or refresh my buffer after every 1 second of time
c) i can not increase my sampling rate..
so can anybody tel me the perfect solution...
its realy urgent for me
Sahara
‎10-30-2007 03:33 AM
Sahara,
Following information will help us to answer your query better
Dev
‎10-31-2007 09:40 PM
i m using NI's cDAQ 9172 chasis for that...
the modules which i m going to use that are ....Analog cards like for temeperature its 9211,,, for current its 9203, for voltage its 9201,,,
the sampling rate which i m going to use is 10000 samples per second...
also i aspect to get the answers that how can i make one data acquisition system using labview..this is my first project which i m going to handle using labview and i think i m completely fail to do so...
so plz can anybody let me know abt the process of making a data acquisition system using labview or u think that u have any VI which gives my answers perfectly than plz attach with this one..
The main problem i had faced during my design is that when i had initize my all three parameter in different three VI, i didnt be able to join or collect the data from all of them...
so plz let one do think that if u have any Sample VI which u think that it will help to me to understand DAQ in LabVIEW than plz help me...
Sahara
