Multifunction DAQ
Showing results forĀ
Search instead forĀ
Did you mean:Ā
DAQ recommendation
I wanted to find a DAQ system for following instrument. It has a 9 pole D-Sub output connector with 0-10V range. Sampling rate can be 100S/s or less so not a  big problem. But on NI website I am only finding 2 D-Sub connection DAQs in PCI-6221 and PCI-6154. The latter is out of my budget which is less than $1000, so leaves only with one option. However, I cannot find PCI-6221 data sheet so I need help in:
1) Getting PCI-6221 datasheet
2) Is there any other DAQ/configuration would recommend that can be better in terms of maybe I can use other sensors also with it not just limited to this instrument (I can buy some sort of adapter for this instrument to connect to DAQ) that way I have some options to consider. Ideally I want the connection from DAQ to my computer to be USB not PCI.
(2,260 Views)
Don't be fixated on the connector.  You can make your own cable, which those using this with a PLC will do.
You could probably go with a low end DAQ such as a USB-6000, which goes for ~$200.
(2,238 Views)
If all that you require are these,
  • Measure 0-10V analog signal
  • Sampling rate 100S/s
I will also recommend the low-cost USB-600x series same as crossrulz and create a custom cable
Santhosh
Soliton Technologies
(2,229 Views)
Ok I see the USB have screw terminals so I would have to do a DSub to screw terminal adapter?
(2,184 Views)
You just need a DB-9 connector (like this one) and some wire.
(2,177 Views)
Since you keep looking for a readily available adapter despite the recommendation to create a custom one, I would assume you're not from an electrical background?
Santhosh
(2,150 Views)
