Multifunction DAQ
DAQ help in automated task
Like I said, I don't use the DAQ Assistant. If wiring the Boolean in does not work, insert a 'Boolean to (0,1)' function. Are sure you have selected a digital output?
Edit - Just really noticed that you are using an analog output instead of a digital. That probably explains why wiring the Boolean does not work. why are you using an analog output?
Message 11 of 17
(1,609 Views)
My output for this is on an analog output here.  I hooked it up before the "not" statement and after and it still only gave me a 1 value.  Insert that Boolean to the output and connect it in sequence with the line coming from the shift register to the assistant?
Message 12 of 17
(1,606 Views)
I have the boolean hooked up after the green line comes in from the shift register to the daq assistant, nothing changed.
Message 13 of 17
(1,603 Views)
Booleans will not work with an analog output. I understand now why you had the 0 and 5 inside the case statement. Use the case statement again or just a Select function.
Message 14 of 17
(1,601 Views)
So go back to using my original VI?  The only thing I'm really trying to workout is the loop.  like once I initialize it, I just want to let the arm go up and down for 100 iterations then stop.
Message 15 of 17
(1,599 Views)
Accepted by emunoz03
That is not at all what I said. What I said was to use the case statement or make it simpler with a Select function.
Message 16 of 17
(1,597 Views)
The thing that worked was inserting the case statement into my loop as a whole.  Thank you very much for your patience and help!
Message 17 of 17
(1,581 Views)
