Multifunction DAQ
DAQ board code for PCI-6713
I need the code the PCI-6713 answer when using functions like Init_DA_Brds. I do not have this board, so I can not use the function to get the code. But I need this because my client's application will work with this board.
(2,520 Views)
Hello;
Functions such as Init_DA_Brds are not only supported by that specific device. You can take the list of functions that the code you are writting needs to have, and then, go to the on line NI-DAQ manual, and figure out which other DAQ board supports those calls.
You do need to have a DAQ board that supports those functions to be able to test those.
Hope this helps.
Filipe A.
(2,520 Views)
