Multifunction DAQ
How can I make DAQ VIs visible when using NI-DAQ 4.9 with LabVIEW 6.0?
My operational system is Windows 98, I am using a AT-DSP2200 card and is configured. I have installed a NI-DAQ 4.9 (the last for this card) and I use Labview 6.0, but I can not find the DAQ VIs on the functions palette. How can I solve this?
(2,179 Views)
Hello;
That version of the driver is too old to work with Labview 6i. The oldest version of NI-DAQ that one can combine with Labview 6i is version 6.1.
You will need either to use another version of Labview, or to investigate a replacement hardware that you can use with newer versions of NI-DAQ.
Regards
Filipe A.
(2,179 Views)
