Multifunction DAQ
DACOUT buffer empties instantly for PCI-6024E but PCI-6071E is OK
We have been using PCI-6024E and PCI-6071E and formerly PCI-MIO-16E series mutlifinction I/O cards in our equipment.  Recently we noticed some of the equipment with PCI-6024E cards seems to dump its DACOUT buffers without correct timing.  This problem is recent - we try to keep the drives, OS, BIOS, etc. current.  We have performed lots of compare/contrast tests and the only failures to date correlate uniquely to the use of PCI-6024E cards.
Can anybody suggest a functional difference on the PCI-6024E to refine our tests?  Are there any reported issues that might be implicated?
I'm the hardware guy - I'll need to talk to our software developer to get more specific about our app.
John G.
(3,121 Views)
A little more description of how u are using your hardware and also a look at your software might help us answer better.
so can u attach your code as well?
regards
Dev
(3,111 Views)
There is an immense amount of code for this  instrument, but the problem concerns the functions listed below.
The NiDAQ is in a Dell 2-card-slot docking station with a Matrox video acquisition card.
The app uses the NiDAQ card to acquire about 100k samples, then displays it in an oscillographic window.  After acquisition & display, external control functions will start and display normally but a PCI-6024E card will finish prematurely.
After acquisition, we initialize the card environment with the acquired data via
   err = WFM_Load(iBoard, numChans, chanVect, buffer, count, iterations, iFIFOMode);
   err = WFM_Rate(rate, iUnits, &iUpdateTB, &ulUpdateInt);
   err = WFM_ClockRate(iBoard, BPO_GROUP, iWhichClock, iUpdateTB, ulUpdateInt, iDelayMode);
   err = WFM_Group_Control(iBoard, BPO_GROUP, BPO_OPSTART);
and then we monitor buffered DACOUT progress with
   err = WFM_Check(iBoard, BPO_AO, &iWFMstopped, &ulItersDone, &ulPtsDone);
which returns error code 10843 when using the PCI-6024E cards but works fine using other DAQ cards.  It could be under-flow  or it could be over-run, but it is unique to PCI-6024E usage with our code.  There may be a problem with some other card driver (video acq maybe) but it only seems to occur when a PCI-6024E is in use.  We need some suggestions as to where to start looking.
(3,090 Views)
Unlike the 6071E (and the PCI-MIO-16E-1), the PCI-6024E has no analog output FIFO. It cannot buffer analog data on the board itself, something that is necessary for the higher analog output clock speeds (> 10KSamples/sec). In addition, the PCI-6024E has only a single DMA channel. If that DMA channel is not available for analog output, your max clock speed drops further (to around 1 KSamples/sec).
(3,084 Views)
