01-06-2006 02:29 PM
01-07-2006 01:55 AM
A little more description of how u are using your hardware and also a look at your software might help us answer better.
so can u attach your code as well?
regards
Dev
01-09-2006 04:27 PM
There is an immense amount of code for this instrument, but the problem concerns the functions listed below.
The NiDAQ is in a Dell 2-card-slot docking station with a Matrox video acquisition card.
The app uses the NiDAQ card to acquire about 100k samples, then displays it in an oscillographic window. After acquisition & display, external control functions will start and display normally but a PCI-6024E card will finish prematurely.
After acquisition, we initialize the card environment with the acquired data via
err = WFM_Load(iBoard, numChans, chanVect, buffer, count, iterations, iFIFOMode);
err = WFM_Rate(rate, iUnits, &iUpdateTB, &ulUpdateInt);
err = WFM_ClockRate(iBoard, BPO_GROUP, iWhichClock, iUpdateTB, ulUpdateInt, iDelayMode);
err = WFM_Group_Control(iBoard, BPO_GROUP, BPO_OPSTART);
and then we monitor buffered DACOUT progress with
err = WFM_Check(iBoard, BPO_AO, &iWFMstopped, &ulItersDone, &ulPtsDone);
which returns error code 10843 when using the PCI-6024E cards but works fine using other DAQ cards. It could be under-flow or it could be over-run, but it is unique to PCI-6024E usage with our code. There may be a problem with some other card driver (video acq maybe) but it only seems to occur when a PCI-6024E is in use. We need some suggestions as to where to start looking.
01-09-2006 04:38 PM
Unlike the 6071E (and the PCI-MIO-16E-1), the PCI-6024E has no analog output FIFO. It cannot buffer analog data on the board itself, something that is necessary for the higher analog output clock speeds (> 10KSamples/sec). In addition, the PCI-6024E has only a single DMA channel. If that DMA channel is not available for analog output, your max clock speed drops further (to around 1 KSamples/sec).
