02-22-2007 05:00 PM - edited 02-22-2007 05:00 PM
Message Edited by aaronSU10 on 02-22-2007 05:00 PM
02-23-2007 04:15 AM
02-23-2007 05:25 AM
02-23-2007 07:05 AM - edited 02-23-2007 07:05 AM
You can set the range of each channel of a DAQ card, on LabVIEW, using 'AI config.vi' in an AI acquisition VI
Look at attached pic
Hope this helps
regards,
Dev
Message Edited by devchander on 02-23-2007 07:09 AM
02-26-2007 12:10 PM
02-26-2007 02:53 PM
You've got a 1 and -1 wired to the limit inputs of AI Sample Channel. Putting the AI Config outside the loop doesn't do anything when you reconfigure the limits inside the loop. AI Sample Channel actuall calls AI Config and passes the +1 and -1 values you have wired up.
Even if AI Sample Channel did not call AI Config, putting the AI Config outside the loop and not wiring data from it to the while loop is a bad idea. You have no guarantee that the AI Config would actually be called before the code inside the while loop starts.
03-05-2007 05:58 PM
How do I enable dithering?
03-06-2007 05:08 AM
03-06-2007 05:10 AM
