‎01-23-2026 06:47 AM
We have a test system with several different loads. Each load has a Compact DAQ module (with network) to control the IO. When we switch our test system from one load to another we have to set permissions in NI max.
Is there a way to avoid this ? We want to swap loads without setting permissions or can we do that in the software. All compact DAQ modules have the same IP address.
When we want to test a different product we must change the load accordingly and thus the Compat DAQ module.
Best regards
Tonnie
‎01-25-2026 06:43 PM
Reserving a CompactDAQ Ethernet Chassis from LabVIEW
‎01-26-2026 12:54 AM
Hello
Thanks for the update
Only problem is that we don't use LabView or CVI.
Our programm is written in C# DotNet.
Do you have suggestion for DotNet as well ?
Thanks in advance
‎01-26-2026 02:05 AM
‎01-26-2026 02:50 AM
@Tonnie wrote:
Hello
Thanks in advance
See example in Reconnect Ethernet DAQ Automatically During Data Acquisition Process
