Multifunction DAQ
Compact DAQ Set permissions
We have a test system with several different loads. Each load has a Compact DAQ module (with network) to control the IO. When we switch our test system from one load to another we have to set permissions in NI max.
Is there a way to avoid this ? We want to swap loads without setting permissions or can we do that in the software. All compact DAQ modules have the same IP address.
When we want to test a different product we must change the load accordingly and thus the Compat DAQ module.
Best regards
Tonnie
(1,607 Views)
(1,570 Views)
Hello
Thanks for the update
Only problem is that we don't use LabView or CVI.
Our programm is written in C# DotNet.
Do you have suggestion for DotNet as well ?
Thanks in advance
(1,559 Views)
There must be an equivalent method in DAQmx .NET dll of Reserve Network Device since all tech stack implementations of DAQmx is a wrapper of the DAQmx C DLL.
Santhosh
Soliton Technologies
(1,552 Views)
Accepted by topic author Tonnie
@Tonnie wrote:
Hello
Thanks in advance
See example in Reconnect Ethernet DAQ Automatically During Data Acquisition Process
(1,547 Views)
