Multifunction DAQ
Cannot install 9162
When I installed the driver for the USB carrier 9162, I got the error as attached picture.  Why?
I have NI-DAQmx 8.5 installed.  I have checked the NI services such as NI Configuration Manager.  They are all started.  I tried the same device in other machines and it works.
(3,937 Views)
Any ideas?
I even have uninstalled and reinstalled all NI software.  It still does not work.
(3,901 Views)
Maybe you need uninstall DAQmx driver and remove register infomation in regedit. Then reinstall DAQmx driver.
(3,868 Views)
I have exactly the same problem when trying to install a 9233 and a 9215A both on 9162's through a 4 port hub on two different machines (a laptop and a workstation).
Once the problem has shown through the 4 port hub direct installation also fails with the same message on each available USB socket.
I deleted all the registry entries for the 9162 and uninstalled the DAQmx driver, rebooted and then reinstalled the 8.5 drivers and the workstation now operates both 9162's through the hub.
I followed the exact same procedure on the laptop to clear registry and refresh the 8.5 installation and yet it still shows the problem.
There are several other related threads with USB port errors during installation of more than one device but none seem to offer a different solution to the one that I have tried with the mixed results.
(3,796 Views)
Repeating the process with a restart after the complete uninstall and again after the hardware found the drivers seems to have cleared the problem.
(3,783 Views)
